Question moderator help?
Morugs
BANNED
Mar 20, 2021
38
i just uploaded a thread/question then edited it and now its gone, on my profile in the your content section its gone and its gone from windows 10 section, why?
Morugs
BANNED
Mar 20, 2021
38
It wasn't "gone", it simply it needed approval.
It is there now.
i tought that it needed approval but it took longer than normally so i was worried a bug might just have wiped it or for some reason you deleted it, anways if you dont mind delete this thread problem solved.
