[SOLVED] Modified Optiplex 3020 d08s with i7 4770k not booting showing no display on working monitor through VGA but orange led and fans are working
Jul 23, 2019
68
7
35
I bought a bare bone Optiplex from eBay.
Here is the link:https://www.ebay.com/itm/Dell-Optiplex-3020-D08S-Barebones-Desktop-SFF-PC-SEE-NOTES/333103739422?ssPageName=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
I put a CPU, https://www.amazon.com/i7-4770K-Quad-Core-Processor-graphics-BX80646I74770K/dp/B017AJ9KNG/ref=sr_1_15?keywords=i7+4770k&m=A30T5A3XNEN021&qid=1572015221&s=merchant-items&sr=1-15 A Crucial 4gb DDr3 Ram stick, and a western digital 7200 rpm hard drive.
Once I finished putting everything together, I hooked it up to a working Acer monitor through VGA (No HDMI port on the Optiplex) , just to see no response. Does it need to be HDMI for whatever reason? If so I just need an adapter cable.
I think my CPU is not chipset compatible, but Then does that mean I should replace the chipset or the bios chip? If the CPU is not chipset compatible it is socket compatible.
I took a look at the CPU to see if its triangle was aligned with The one on the board, and it was, so I looked under it, and guess what I saw. .. ... .... ..... ...... ....... ........ ......... ..........
BENT THREADS! How do I bend them back in to place? Will the BIOS not show up if there are a few bent threads on the socket? If not than what other problem would there be?
The seller has really good reviews.
The CPU fan turned on, and the orange LED turned on on my motherboard. What could have happened?
-Leo
How am I supposed to update the bios if it does not even show up?
The monitor did not detect anything.
You would need to try with a known, supported CPU, probably an i3 or i5 Haswell.
That's assuming that the problem is with the CPU, either the CPU being defective, or simply unsupported by the system (either because of an older BIOS, or simply that it was never designed for that CPU). The bent pins will definitely be a problem, though I'm out of my league when it comes to dealing with that.
I can't speak for the bent pins or anything, but it might be that before upgrading the processor, the latest version of the BIOS might need to be installed.
Was there no CPU or RAM in it previously?
By the way, $400 is WAY too much to pay for an old 4770K. Their original release price was $339.
Jul 23, 2019
68
7
35
Yes. This was called a bare bone PC. This is when all parts are taken out besides the"Bones" the motherboard, power supply case optical drive, etc. So just the minimal basic parts.
Well, getting the RAM directly from Crucial is good, because they guarantee compatibility.
As to the BIOS, there definitely are updates. I don't have the service tag code, but going here:
https://www.dell.com/support/home/us/en/19/product-support/product/optiplex-3020-desktop/drivers
And choosing BIOS shows that version A20 was made available on June of this year.
Do you have a lower-end Haswell processor, say an i3, or an i5 (not sure if a Pentium would work) to try it out with? Also, am I correct in assuming the heatsink was installed on the CPU and fan was operational?
Jul 23, 2019
68
7
35
It was at first, until I came back to my Optiplex after taking a break after trying to fix it. Now I only see The smallest puff of air coming from the fan after pressing the power button. Or I can hold the power supply button if I want to see the fan slowly running at a low rpm. First it started running as soon as I plugged it in.(the power button did not show any sign of any response) Now I have to hold the psu button on the power supply if I want the fan to spin but it runs extremely slow now.
I do not know what could have caused this.
Jul 23, 2019
68
7
35
I found out that the i7 4770k is chipset compatible.
This shows the chipset of the optiplex https://www.levnapc.cz/ProductsFiles/Dell-OptiPlex-3020-technicka-specifikace.pdf
and these are the compatible hipsets of my 4770k:http://www.cpu-upgrade.com/CPUs/Intel/Core_i7/i7-4770K.html.
They are compatible. The optiplex motherboard uses the Intel H81 chipset, and the 4770k is compatible.
While that's true on a general level - OEMs don't always play by exactly the same rules.
For example, the Intel chipset used on the motherboard of my Dell XPS 8300 was compatible with Sandy Bridge and Ivy Bridge processors, but Dell never updated their BIOS to support Ivy Bridge on it.
That said, while the Haswell CPUs in general are compatible with your system, there may be these odd situations because it's an OEM board for Dell. I couldn't say for certain.
Jul 23, 2019
68
7
35
Ok thanks. Maybe I will try. But it could have been the cable that was not working the entire time. But I will try that with a really cheap i3-4130 or something. Thanks.
Reactions: King_V
