Question modify low power /idle/ memory clock on Rx 570?
bobalazs
269
12
I'm trying to increase the default idle 300 Mhz memory clock of rx 570 with MSI AB. as it often causes graphical glitches. i edited voltage curve with control-F but i dont see any option to modify idle memory clocks, only the 3d clocks.
Any tips on how to go about that?
well, u cant, its in gpu bios
u can disable powerplay (downclocking feature)
open msi AB, open settings
check "Disable ULPS"
click teh dropdown of "Unoffical overclocking mode" and select "without PowerPlay support"
click OK and restart msi AB
bobalazs
269
12
Thanks i guess, but that's not really what i want to do. Neither do i want to go into bios editing, actually i'm just looking for an option to help myself and others that run into this generally common situation where the rx cards have graphical glitches while in low power mode.
bobalazs
269
12
Well i found a half-solution. I went to wattman settings and under global wattman-memory - STATE 0 Min STATE 1 STATE 2 Max
i clicked STATE 1 and "set as minimum state"
So that means i don't idle to 300 Mhz, but no graphics glitches at all no matter what i do. Power consumption however increased by about 7 watts (pulled from wall)
