Modular psu to gpu help
Andrew_263
76
Hey I got evga modular psu. It came with 2 vga GQ that I presume is pcie and they both have 2 6+2 pin connectors.
Now I also have a evga gtx 1080 ftw gpu that requires 2 8 pin female power connectors. and comes with 2 8 pin male connectors spit into 2 6 pin female connectors.
Now how do u plug the gpu in do i use the coards that came with the gpu and plug 4 6pin into it? Or do I use what came with the psu? If I'm using coards from the psu do i use 1 coard with 2 6+2 pin on it or 2 separate cords using a 6+2 from each coard???
OK this confuses me alot... and it might confuse you too sry bout dat. Any help would be great just don't Wana fuk up first build thanks
Ok so 1 coard from psu with 2 6+2 headers thank you so much and question why not coards from gpu and is it ok to use 2 separate coards mainly so the coards don't hit the side panel
