Moga Power Pro (HID B mode) wont connect after initial pairing.
Morgan Gerrell
9
Hello all, I have a problem with my Moga Power Pro on my PC in mod B (HID). First and foremost I am running Windows 8.1. My Moga doesn't want to reconnect after the first use. I am able to pair it with my Bluetooth adapter, and when asked for the code I leave it blank. Once it pairs the controller works like a charm. However once it goes to sleep or I turn the power off, it will not reconnect. I have to manually remove the controller from my paired devices and then re-pair it. This process is very annoying.
Something else, once my controller turns off and back on, as stated above it will not reconnect (and work) automatically. it attempts to reconnect, the 4 blue lights flash and my PC will SAY it is connecting, but once it 'connects' my 4 blue lights on the controller still flash and after a few moment the PC will go from 'connected' to 'paired' and start the connection process over again.
I would very much appreciate any and all assistance! Also, I am very new to this forum (only used once before and had my problem solved) and am not sure if I have left any vital information out so just let me know if so and I will get it on here.
I apologize for the post... I have found the solution to my own problem. The issue was with how I was trying to connect it to my PC. I was leaving the pair code blank on my PC as I didn't think it had own. After trial and error I have found that the pair code is '1234' and after connecting it to my PC using the code it works as should (albeit without the triggers). I am leaving this up however for the next person who has this problem. I hope it helps someone!
