Molex motherboard connector problem (graphics card)
BiGsTaM
5
I have had bsod problems since rebuilding the system, doing "cool" cable management (to say the least it was shit), and stretching the cables to minimize the amount of cable shown, even though I didn't and still don't have a glass side case. Anyways, now it seems that I've bent the molex graphics card connector on my motherboard. I couldn't see that I bent it but I checked the bsod code I got, and confirmed with my trusty multimeter that indeed the motherboard connector was not working. How can I fix it?
AFAIK only few MB have that, also when you use two or three GPU, you will need that. SO what MB did you have? How many GPU do you use? If you use only one GPU you can forget about it, you can't fix the broken connector on MB, you will need the new MB if you have to use that connector.
Sorry for the late reply, didn't see the email. This is the only gpu I have in that system, so I'm currently doomed... Shit... Thanks for the help though! :)
