Right, I need some help confirming two things,
I know 3pin fans can be Voltage controlled and 4pin are PWM controlled. And I know that I can add a molex splitter to my MB header to increase my connections like in the link below, but....
http://
1. I have a CPU header for my CPU used, but only one chassis fan header (ITX MB). But I have 2 case fans and want to install 2 extra external fans.....(HTPC is in a closed TV unit so is overheating....so I want to put a fan drawing cool air from underneath the TV unit and one exhaust fan removing air out the back). IF i connect a x4 molex PWM splitter to the chassis fan header and connect the 4 fans (2x 3pin + 2x 4pin), will the motherboard utility work (ASROCK FAN-tastic tuning) and control them all as if they were one fan?
2. IF yes, I assume the 4pin fans will be RPM controlled but will the 3pin fans just spin at 100%?
PS - I am just building the PC at the minute and dont have all parts so cant test completely just yet, I just dont want to order the 2 extra 4pin fans and splitter if this is not going to work well!
Corsair 250D
ASROCK B86M-ITX
Intel i5-4460
Arctic Freezer 13 (it fits easy in this case althought specs say 95mm max!!)
Thanks for any help or suggestions!!
http://
Corsair 250D
ASROCK B86M-ITX
Intel i5-4460
