Monitor´s Recommended Resolution Doesnt Fit Properly
Yanezez
Hello everyone,
Im having an issue on one of my monitors. The model is LG M2241a.
I have it connected to an HDMI cable, ATI RX480 video card.
When I try to choose resolution it shows the Recommended Resolution at 1920x1080 like it should. However even that resolution is off and seems to zoomed in for the screen, leaving parts of the interface cut off.
All resolutions are off. Any help please?
You have to plug the HDMI cable into "DVI" HDMI. I had this issue. The port you plugged it in doesn't understand computer signal so it gets messed up. There should be multiple HDMI ports that you can plug into, one of them is the one to plug computers HDMI in.
Only buttons I can see from page 4 of online manual are three buttons on the back- a Mode button that allows selection of Channel /Volume/Input and two buttons below that adjust the level of the chosen Mode.
