Question Monitor 1920x1017
yohaNi
Commendable
Feb 16, 2017
26
Hi, earlier today I plugged my xbox one into my monitor. If anyone is curious my monitor is called
Samsung S24F350FHU
It's supposed to be 1920x1080 but I can't get it higher than 1920x1017 for some reason, I've tried different cables, even installed the new drivers. What should I do?
Mind sharing the make and models of the HDMI cables you've used? A link to them would help two fold. You could try and connect the Xbox One to a known working TV with existing cables in your neighbors household and see if the cables you have are the issue. You might also wan to see if the display itself has an inherent issue when connected to a machine via HDMI.
