Monitor 2 battery backups from one computer
kr0490
274
Does anyone know if there is a way to monitor and control 2 ups units from cyber power connected to the same computer using usb via cyberpowers powerpanel business software? I know i can control 2 computers to shutdown with the software, but i want to monitor 2 separate ups's from the same pc? Is this possible?
My first thought was that you might need to run two instances of the software and that the software would need to permit you to select the USB port being used. Provided that that approach was supported by the software.
That said I did some research and found the applicable (I think) User Manual here:
http://www.cyberpower-eu.com/support/download/PowerPanel_Business_Edition_EN.pdf
See page 7.
In the bottom paragraph discusses the use of a remote management card/ client set up. Not sure if that is a viable arrangement for your environment.
See page 7.
