Since the beginning of computers, their resolution never stopped to improve.
1920*1080 was a great achievement ... 5 years ago.
Even a small tablet can offer now much better than that (iPad3: 2048*1536).
And test prove that the latest GPUs stay unexploited at such resolution (not mention CrossFireX and SLI)
It is time to think bigger!
I know 1920*1200 exist but it's only marginally better,
and 2560*1600 or 2560*1440 are just way too much $$$.
We also know that a more square ratio is better adapted for computers:
web surfing, Email, Office, Development...
So, while keeping with an incremental 'easy' step,
I believe a monitor with a resolution of 1920*1600 looks perfect!
You can still play movies in full HD if you want!
Now, if you add to it a thin bezel for its largest sides (1920),
you get a screen that can easily extend to 3 by adding 2 cheap standard 1920*1080 on both sides.
And you get:
Vertical: 1920
Horizontal: 1080 + 1600 + 1080 = 3760
A ratio close to 2/1 with more than 7.2 Million pixels for gaming!
Interestingly, the height of a 27'' (1920*1600) will be similar to the one of a 23.6'' or 24'' (1920*1080) monitor, while the height of a 26'' (1920*1600) is close to the one of a 23'' (1920*1080).
Compare to the 5 vertical monitors of 1920*1080,
it's much less bulky and has twice less bezels to deal with (2 instead of 4).
The center of the config, which is the most important, is also cleaner.
Why couldn't Samsung, LG and others create such new standard?
Technically, it doesn't look so difficult...
And you get:
Vertical: 1920
