Monitor Advice
mastrom101
1,477
Hi,
I'm looking for a new monitor, preferably 22-24 inches, and 1080P. It's main use will be for light gaming and multitasking.
I want to spend under $150, so what is my best bet?
Also will the Intel HD 3000 be good enough for multitasking while i wait for a deal on a GPU?
In general, Asus makes pretty good budget oriented monitors. The Asus VE228H 21.5" has some pretty good user reviews and $135 after rebate + shipping.
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236100
There's also the 23" ASUS VH232H for $145 after rebate + shipping.
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236079
As long as you do not plan on playing games, the Intel HD 3000 integrated graphic core is fine for multitasking. Multitasking is dependent on the CPU core, not the GPU core.
