• Now's your chance win big! Join our community and get entered to win a RTX 2060 GPU, plus more! Join here.
    Pi Cast Episode 3 streams live on Tuesday, August 4th at 2:30 pm ET (7:30 PM BST). Watch live right here!
    Catch Scharon on the Tom's Hardware Show live on Thursday, August 6th at 2:00 pm ET (7:00 PM BST). Click here!
Question Monitor and HDMI
Dec 30, 2019
19
I just bought a new monitor with refresh rate of 60hz, but it doesn't seem like everything is running in 60 fps. Some windows animations, and from time to time in some games. Is it maybe because of HDMI cable? Youtube videos are running perfectly in 60 fps. HDMi cable came with monitor. It is completely new.
Dec 30, 2019
19
I know that, and GPU can run most of the games in 60 fps, but some animations on windows like clicking on windows button doesn't seen so fluid. It's like it is running in 30 fps. Maybe I could try changing hdmi ports( to change sides)?
I don´t think it´s an HDMI issue
Check your SSD´s connection. Is it connected to SATA 3 and not sata 2?
use samsung magician to check your SSD and if available update the firmware of it
check the temperature of your CPU using the tool coretemp. read the max. temp. while windows is lagging
check windows integrity
open the command prompt as administrator and type DISM /Online /Cleanup-Image /RestoreHealth
https://www.lifewire.com/how-to-open-an-elevated-command-prompt-2618088
https://answers.microsoft.com/en-us/windows/forum/windows_10-update/system-file-check-sfc-scan-and-repair-system-files/bc609315-da1f-4775-812c-695b60477a93
clean boot
https://support.microsoft.com/en-us/help/929135/how-to-perform-a-clean-boot-in-windows
sandy bridge is usually supporting sata 3, had an H61m from ASRock
but these boards have SATA2 and 3 onboard, so it depends on where the SSD is plugged in
also AHCI has to be enabled in BIOS
check with the tool AS SSD
