I connected monitor with vga cable,tv with hdmi on same gpu.When connected together,can they have different resolutions?
Right now it looks bad on tv.
Max resolution on monitor is 1680/1050,tv is HD Ready.
That is a possibility as well. You might be able to use Extend Display and then have them at different resolutions and then use over/underscan to get your TV to the correct size.
In short yes. Each monitor can be sent a different resolution, however, when gaming with both screens on you might have a problem. I had to game at the lower of the two resolutions on my monitors.
