Monitor and USB slot no longer work
Spasticninja03
5
So I recently built a computer with the help of the friend and the computer was all fine. But the stock cpu cooler sucked so i installed a new one yesterday. I turned the computer on and everything in the case lit up and was running well put my mouse and keyboard didnt work and didn't light up. The monitor which I connect through a hdmi turned on but it had no signal. The strange thing was my headset worked so im really confused. The only thing I can think of is I must have damaged the motherboard while installing the cpu cooler or something. Any help is really appreciated thank you in advance.
My mobo doesn't have 3.0 slot so I can only use the 2.0 USB slots. My headset works on all the USB slots and the mouse and keyboard dont work on any of them. I have connected the mouse and keyboard to another computer and they worked on that one.
Becuase its an amd cpu i didnt have to remove the motherboard to install the cpu cooler so the only wire i touched was the cpu cooler wire.
That didn't work. I forgot to mention that pressing the power or restart button doesn't turn off the computer the only way to turn it off now is to hold in the power button not sure if this helps.
Also I don't get what you mean by 'what of the monitor?
Case: Thermaltake commander ms-III ,motherboard: msi 990FXA-GD65, ram: corsair vengeance 8GB, CPU: AMD FX 8320, CPU cooler: noctua NH-U9B SE2, PSU: thermaltake litepower 600W black edition, GPU: asus nvidia GeForce GTX 760, PCI Adapter: TP-LINK 300mbps wireless N PCI adapter, monitor: LG LED 24 inch, keyboard: logitech g510s, mouse: logitech g500s, headset: plantronics RIG.
Me and my friend built the pc about 2-3 months ago
