Question Monitor Arms for UW and 25”
gui0312
Commendable
Mar 15, 2017
42
I wasn’t sure where to post this since it included “monitors’ I thought this would be the best place. I have an Alienware 34 UW 3418DW and a 25 Alienware AW2518, I want to set them up on arms but, not sure if a dual arm is good for this with regards to support and size. Should this or can this be done, I was looking at the amazon basics which I read good Reviews on but, my question wasn’t answered there.
Thanks!
VIVO-US
Respectable
Feb 1, 2017
250
8
1,865
32
Yes, this would work perfectly fine. If you use a dual monitor mount, just make sure you use one rated to hold at least 30" monitors (preferably 32" or larger to give yourself extra room) to account for the extra width of the 34". Also, since the 34" monitor weighs 16lbs without its original stand, the mount will need to be able to support that much per bracket.
Reactions: gui0312
gui0312
Commendable
Mar 15, 2017
42
Awesome thanks!
