Heres the link
View: https://youtu.be/pDKb_x6wlbU
(IT GOT A LOT WORSE AFTER THAT VIDEO)
hello, recently one of my pc ram died and i did some troubleshooting cuz it was not posting and i somehow ended up killing my GPU cuz it doesnt have the 6 pin on it. ( i did my research it wasnt suppose to do that they say ) after figuring it all out, it worked fine. i bought new ram and it was the same as before. But after a couple of days or weeks. my monitor suddenly showing some artifacts flickering on top of the monitor and eventually the whole screen.
It just happened all of a sudden. I also tried to use CRU where i set my refresh rate below 75hz and it still shows artifacts flickering. what could be the problem??
What i have tried.
-Change cables (X)
-Experiment in changing my refresh rate in CRU ( X ) currently on 69HZ. still artifacts
- tried to see if there was any lose cables in my PC ( X )
- tried resetting my monitor settings ( X )
- tried experimenting on my monitor settings ( X )
do you guys have any recommendations or should i just wait until this monitor gives up and buy a new one. (the monitor is 1 years old btw)
THANK YOU !
What i have tried.
-Change cables (X)
THANK YOU !
