Monitor BenQ help
comxmonster
6
If I buy a monitor from the USA and use it in the UK will I have problem? I know that in the US the voltage is 110 and in the UK its 240. All I need is a voltage converter. But the problem is that if I connect the desktop with the monitor wouldn`t it damage anything cause of the voltage that passes through the desktop? So I don`t know how much volts the graphic card produce.
My graphics card : http://goo.gl/UlYwGL
The monitor : http://goo.gl/jEPXMa
Converter : http://goo.gl/b4uaCw
Similar threads
