I have a Sceptre X24WG monitor that is usable, but stuck on the lowest brightness setting. If I use the menu / OSD to try to change the brightness it shows a bunch of 0s for the value, and the monitor's software freezes. The menu becomes permanently on screen, and all monitor buttons stop functioning. The only thing I can do is unplug the monitor and plug it back in.
Has anyone experienced this before? Is there anything I can do to get the brightness back to normal?
