• Hey there, Guest! Share your idea for a new trophy in the forums and win bragging rights and a $100 Amazon gift card! Check out the New Community Trophy Contest here!
  • Pardon our dust as we work on some regularly scheduled forum maintenance. You may notice some missing features during this time. Thank you for your patience!
Monitor cables
ls86
48
Have a noobie question on monitor connection. I'm using a D-sub or VGA or whatever you call the old version cable on both ends to connect my monitor to my graphics card. Since my graphics card is kinda new, I used a DVI converter to connect the other end to the card. So when I play games I have those horizontal ghost line moving up and down. I think it is the cable or the converter's problem.
So my question is will a newer digital cable solve the issue? If so, what kind should I purse would be the best, a HDMI to DVI adapter cable, or just a simple dvi to dvi cable? BTW... my monitor has a 24-pin DVI port. Will it work if I plug in an 18-pin DVI port?
Thank you :)
trapper
679
74
If your monitor isn't larger than 1920x1200 any standard DVI cable would work, and would be your best bet. If you have a large resolution (2560xsomething) then you'd need to get a dual-link DVI cable. Getting an HDMI to DVI cable would just be adding unnecessary complications.
That should fix your problem.
ls86
48
The resolution is 1680 x 1050. So I guess a standard DVI cable would work.
Thank you very much :)
Similar threads
