R rds93 Jul 5, 2018 4 0 10 Jul 5, 2018 #1 I have a 24” Full HD 144 hz Acer monitor connected to a GTX 1080 with a a HDMI cable. I don’t know why it’s capped to 60 hz, I didn’t find any drivers online since the latest version is for Windows 8 and I’m using Windows 10 How do I fix this?
Solution Barty1884 Jul 5, 2018 Which monitor do you have, specifically? While a 1080 has HDMI 2.0, chances are good the Acer monitor has HDMI 1.4 and does not support 120+Hz over HDMI. http://www.tomshardware.co.uk/forum/id-3675170/connect-120-display-construction.html?_ga=2.6735026.1420936986.1530629099-183779354.1518709239 DisplayPort would be a better option
Barty1884 Retired Moderator Apr 16, 2015 22,254 1,355 108,740 Jul 5, 2018 Solution #2 Which monitor do you have, specifically? While a 1080 has HDMI 2.0, chances are good the Acer monitor has HDMI 1.4 and does not support 120+Hz over HDMI. http://www.tomshardware.co.uk/forum/id-3675170/connect-120-display-construction.html?_ga=2.6735026.1420936986.1530629099-183779354.1518709239 DisplayPort would be a better option Upvote 1 Downvote Solution
Glenwing Splendid Aug 8, 2015 3,208 350 25,990 Jul 5, 2018 #3 If it's the Acer GN246HL, the HDMI port on that monitor is limited to 60 Hz at 1080p. See Section 0 of the guide linked above. Upvote 0 Downvote
