Question Monitor delay
Dec 7, 2023
Hello,
So I have a pc which I'll display the specifications below. I noticed I was getting horrible delay when I had two monitors connected, so I removed one of the monitors and nothing has really changed, maybe a small improvement but it's still frustrating when playing games. It's strange too since the mouse works perfectly and there's no input delay, it's like the visual side of things is messed up. I've got the latest graphics driver and still the same, just not sure what to do anymore. I had the same problem with my laptop too, when I used the laptop screen there was no delay, but when I plugged a monitor into my laptop there was a visual delay but with no input lag. I hope someone can help.
Thank you.
Specifications:
Ryzen 5 2600 6c 12th
Nvidia 1650 Super GPU
16gb ddr4 3200mhz ram
550w PSU
4x256gb ssd
1x256gb m.2
Monitor:
Benq XL2411k 144hz 1ms
to have a look what the problem could be:
run userbenchmark.com and post the http link of your result, e.g. https://www.userbenchmark.com/UserRun/28977730
check windows integrity
open the command prompt as administrator and type DISM /Online /Cleanup-Image /RestoreHealth
https://www.lifewire.com/how-to-open-an-elevated-command-prompt-2618088
https://answers.microsoft.com/en-us...em-files/bc609315-da1f-4775-812c-695b60477a93
clean boot
https://support.microsoft.com/en-us/help/929135/how-to-perform-a-clean-boot-in-windows
check the memory by running memtest.org usb autoinstaller (bootable USB flash drive)
check the hard drive for errors with its manufacturer´s tool and if available, update the firmware
use ddu uninstaller and reinstall the latest graphics driver
