[SOLVED] Monitor dilemma
Terry1978
75
Hi all after upgrading some parts of my pc i think that i shoould get a gaming monitor also !!!
at the moment i have a Iiyama ProLite XB2380HS (IPS) it has given me an outstanding performance back in the day when i used the asus 660ti GPU
but know i think that i need to change it for somethink more towards Gaming so my Strix GTX1060 6GB dose not go to waste also to get rid of some minor problems like aiming and screen tearing . Have done a bit of reasearch and canot make up my mind wich monitor to by from the folowing 3 :
What hapens if i get the Iiyama with freesync will i have problems with it or ... ?
Iiyama G-MASTER GB2488HSU-B3 is with freesync dose not have G sync
DELL ALIENWARE AW2518H WITH G SYNC
ASUS ROG SWIFT PG258Q WITH G SYNC
please advice me thank you all .
yes I am looking for 1080P/144hz dont think my gpu will handle somethink higher budget about 500 euros i also watch dvd s on my pc
was near geting the Alienwhare tbh but not sure so i posted here .
must have the best performance out of my 1060 6gb gpu i play e sports with a clan ...
Think i gona by the ASUS ROG PG258Q
will my pc be able to handle this monitor at 240Hz i play mostly a game with airoplanes fps gows up and down alot 150 to 350
windows 7 with i7 3770k
and the rog gtx1060 6gb
Overclocking the CPU should give you a bit more FPS but I would just adjust graphic settings accordingly until you get a pretty stable high FPS with minimal dips. The Gsync will also help.
Just whant to be able to run the game smooth with out trying to guess where my target is gona be... thats one of the reasons i am not going for the Iiyama but if i did have a AMD set up Iiyama would be my choise ... dont trust the freesync to work for me and not many monitors with Gsync in the area of 500 euros and under that have got a realy positive review !!!
