I have Benq xl2420L 24 inches Monitor with refresh rat shows 60hz only with graphic card zotac 650ti. Please advise which graphic card can support 144hz with benq xl2420L.
A Benq XL2420Z would support 144hz over DL DVI-D or DP . the DVI cable comes out of the monitors box. DP cable is optional. there isnt any HDMI support for 144hz. having the gpu drivers installed you should be able to properly set monitor to 1080P@144hz . your gpu has support for 144hz since it has Dual Link DVI .
