Hi,
Can someone help me with my second monitor?
View: https://imgur.com/a/eOoZI0K
The small monitor is my second monitor and bought yesterdy.
It's weird brand Hugon 24 inch curve 75hz . After install, the display a bit blue compare to my primary monitor. The cable is HDMI.
Both panel is VA.
My primary monitor ( big One ) is AOC CQ27G2.
Even it cheap and consider no brand monitor but atleast the color can be normal right? not like that. It's too obvious.
I try change the setting:
Any other setting i need to look for?? Please advice me.
I dont knw how to set color in my nvidia panel. I scared if i mess it up.
Both panel is VA.
- From cool to normal
- On HDR
- Set Color profile to custom and lower the blue ( cannot lower below 40 as the display will turn darker even the brightness is 100% )
