Monitor displays only white. Need help.
phuzed
39
Little background on this monitor. When it was working, I always had to turn the power on and off and back on again for it to display. Did this and it worked fine for 3 years.
I recently dropped it on the ground and even after that it worked but had red, green, blue lines on the right side that would slowly go away after it warmed up.
Well now screen might display for a split second and then goes all bright white.
My question is what might be causing this particular issue? My warranty is up so I feel inclined to open it up and see if there's something I can do to fix it. What should I take a look at in there that might be causing the monitor to go all white?
Any help would be greatly appreciated. Thanks.
