Question Monitor does not get signal and VGA light and boot lights are on.
Dec 15, 2020
9
I turned off my PC at night and the next day it stopped working. It was working fine the night before and I did nothing to it. I took out the CMOS disc and still had no luck. I don't understand why my VGA light is on because I didn't mess up my PC. My PC isn't old either, it's around a year old. Plz help!
tecmo34
Administrator
1) Have you tried a different cable or taking the cable out and putting back in? The cable could be bad or gotten loose some how.
2) Have you tried shutting the PC down, taking the GPU out, re-seat it into the PCIe slot and reconnect the power?
3) Have you tried a different card in the system (or your card in a different system0?
These are a few tips to try, specially if everything looks to be starting up.
