Hello everyone,
I've searched the internet for a while, but so far I have found no solution for the following issue:
When I place my GPU (This One) into my case, my monitor connects (The "Cable is not connected" message does not show), but it still receives No Signal.
Wether I put my blue DVI cable in the onboard slot or the slot on the side of the GPU itself, the issue remains.
I've checked the BIOS to see if there's a Graphics Adapter preference, but the only option like that is "Enable Onboard Graphics" which is enabled and grayed out. I do not have the ability to change it.
Any ideas how to fix this?
My specs are:
Thanks!
My specs are:
OS: Win 8.1 64-bit
System Manufacturer: Acer
System Model: C-VE430
BIOS: P21-A4
Processor: Intel Core i3-3240 CPU @3.40GHz (4CPUs), ~3.40GHz
4096MB RAM
DX11
Thanks!
