Hi everyone,
my problem is that 3-years old computer worked just fine for 3 years, but suddenly when I changed my mouse for another, older one (USB->PS2) one of those low budget ones, you know the type, just needed to work (the mouse worked when I connected it earlier), poof! My computer now starts up normally, fans are working and Windows is starting up, but my monitor doesn't get the signal, it gave a beep sound earlier, and now it doesn't. Could you possibly tell what is the problem or what should I do?
I do not know whether the problem is connected with the mouse change, but I thought I should mention it.
My computer specification is:
Powercolor ATI Radeon X1950 Pro 256 MB VRAM
2x1 GB Kingston 667MHz DDR2
Intel Core2Duo E2160 (no OC)
Windows 7 Ultimate 64bit
Gigabyte GA-P35-DS3L
Amacrox Warrior 450W
), anyway thanks for trying to help.
