Hello , i have this monitor for 2 months already working fine Dell UltraSharp U2515H 25" LED
The problem is the following... Last night i switched off computer/monitor then i went to bed and i realized that computer was still on , so i tried to switch on monitor to see what happened and a message poped up '' Entering Power Save Mode '' , from this moment till now i can't get rid off this message.
So i tried to replace RAM to a different , Plug off and in the GPU with no results, the same message.
Then i pluged in my old monitor and it is working fine , however i tried to plug Dell monitor back and i switched from DisplayPort connection to MiniDisplayPort connection in monitor panel ( both are connected at the same time since 2 months ) and it works on mDP but not in DP.
Any idea what can be causing this problem ?
Any real difference for gaming ( recording and renderizing also ) between mDP and DP ?
