R RJones31988 Reputable Sep 29, 2015 27 0 4,530 Sep 17, 2016 #1 I've been recently noticing flickering going on with both of my monitors. I've checked all connections and the monitors are not old at all. My GPU is definitely not old, it is an EVGA 1070 FTW so I'm not sure what the issue is here..
Solution ffg7 Sep 17, 2016 try using 1 monitor at a time to see if still have that flickering issue or not.
S Sayainboy Commendable May 17, 2016 17 0 1,520 Sep 17, 2016 #2 Have you recently updated the drivers for your card? You can check if it is a known issue with the drivers and OS you are using on the NVIDIA website. Upvote 0 Downvote
ffg7 Judicious Apr 7, 2015 5,924 2 34,665 Sep 17, 2016 Solution #3 try using 1 monitor at a time to see if still have that flickering issue or not. Upvote 0 Downvote Solution
