Monitor flickering, refresh rate problem
Jotun
24
Hello,
A few days ago I bought a new monitor because my old one was broken. It worked completely fine until, well, now. The monitor I have is SyncMaster S22B300B, with a native resolution of 1920x1080. And it worked fine up until today. Yesterday, no problems at all. This morning, I turn my PC on, and I notice the resolution is wrong. I check the resolution and somehow it was set on 1440x900, and the max I could set it was 1600x900. I decide to reinstall my drivers, so I start downloading them. While I was doing that I reinstalled my monitor drivers which I had on CD to see will that fix it. I restarted my computer, and there it was, the native resolution. I put it on native resolution, but the screen looked very wrong. First of all, the letters and everything looked very blurry. Then, the screen was somehow flickering, I don't know how to explain it very well. Sort of shaking and stuff. I go to Properties and in the "Screen refresh rate" it says "29 Hertz, Interlaced", while before (I think) it was 60 Hertz.
I reinstalled my graphic card drivers but that didn't help at all. Same thing. I get this flickering on my native resolution and 1680x1050, while lower resolutions have normal refresh rate of 60 Hertz. In the Catalyst Control Center, when I go to desktop properties, there too I can't change the refresh rate for the native resolution. Max is 30 hertz. The control panel also says that my monitor is a "CRT, Analog" and in Properties (VGA Display) it says "Not supported"..
Also, my graphic card is Radeon HD6950.
Thank you in advance.
Hey, thank you for the reply, but I fixed the problem. Appereantly, my cable was loose. All I did was push it in a bit and the resolutions and refresh rates got normal again.
i also have the same problem..after reverting back my Intel HD 4000 driver to its original version(from resource CD),the flickering of screen when refreshing is the result..i cant change the refresh rate(60Hz) because there's no option for it..im sure its not the loose cable.laptop hasn't been opened.. pls help.. thanks in advance. 😉
