There's a few possibilities here.
- 1) The memory
Try removing the memory sticks and cleaning the sockets with some compressed air.
Then for the memory itself, you can lightly rub an ink eraser along the connector strip on both sides of each memory stick to clean the contacts before reinserting the memory.
- 2) With Windows Aero turning off so the taskbar and window borders turn solid instead of clear, this is usually the result of a driver or program compatibility issue.
Windows Aero can also be affected by memory issues.
Seeing as this has been happening for the past month and when you do a restart, it just crashes, forcing you to use a Restore Point, it's possible that Windows Update may be automatically trying to install an incompatible driver on your system each time.
If this is the case, then you may want to change your Windows Update settings to "check for updates, but not to install anything, check with you first." That would hopefully solve the problem of Windows Update automatically installing incompatible drivers.
What with the crashes, I would hope that you at the very least ran a Disk Scan to check the drive for any corruption? Just using a Restore Point won't fix any Corruption of the drive tables.
Windows Explorer - Right Click on
Local Disk ( C: ) > Properties > Tools > Error-checking > Check now button, click the Start button.
It'll tell you
Windows can't check the disk while it's in use Do you want to check for hard disk errors the next time you start your computer?
Select
Schedule disk check button, then close everything out and restart your system (or in your case, shut down, then turn it back on).
The other thing I can think of would possibly be Malware of some sort.
While I may know my stuff with finding and removing various forms of Malware including RootKits and such, Remote support is not my strong point as I need to personally work on system when doing that sort of work.
So Instead, I'll just say, check your system first to eliminate the hardware issues, then check out the information I posted to someone else's thread as it may very well be useful to you if you do have any Malware or Rogue programs on your system.
Please ignore the first paragraph of this linked post
This thread has some useful configuration info for SpyBot-Search & Destroy
