J Jojie_ Commendable Jan 31, 2017 3 0 1,510 Jan 31, 2017 #1 Hi guys, im newbie here so please bear with me.... Im thinking of buying new monitor, as of now i have rx460 as my gpu but also planning to change it gtx 1060, does gtx 1060 support 144hz on 1080p? Do i really need 144hz for monitor?
Solution Dr Girlfriend Feb 7, 2017 Depends on the games you play and budget really. 144hz is nice, but not needed. The 1060 does support 144hz.
Dr Girlfriend Reputable Sep 12, 2015 342 0 4,960 Feb 7, 2017 Solution #2 Depends on the games you play and budget really. 144hz is nice, but not needed. The 1060 does support 144hz. Upvote 0 Downvote Solution
J Jojie_ Commendable Jan 31, 2017 3 0 1,510 Feb 8, 2017 #3 Thanks for the answer, ill be playong more of mmorpg, csgo and nba.. do i need gsync with 144hz monitor? Or 144hz w/o gysnc will be fine? Upvote 0 Downvote
Dr Girlfriend Reputable Sep 12, 2015 342 0 4,960 Feb 8, 2017 #4 Personally I wouldn't buy one without, but that's me. Plenty of people go without. If you can afford it, go for it. If not, don't worry about it. Upvote 0 Downvote
