Monitor for 1060
jerfop12
Commendable
Dec 16, 2017
246
Hi,
I currently have the 1060 3GB OC, (WINDFORCE) running with my monitor:
phl 223v5
I want to buy a second monitor, can i buy a second phl 223v5 and will it work?
If not what monitor do you guys recommend for around €100, thats comp with 1060 3GB OC Windforce.
Greetings & thanks,
jf.
It has output:
Output
Dual-link DVI-D *2
HDMI-2.0b*1 (Max Resolution: 4096x2160 @60 Hz)
Display Port-1.4 *1 (Max Resolution: 7680x4320 @60 Hz)
you can add any monitors, just need the correct cable, assume you already uses HDMI port, you need DP to HDMI or DVI-D to HDMI cable if your second monitor uses HDMI only. If you want same monitor that is fine.
