I have an Optoma HD20 projector in my theater room that does 1080p/24hz for native blu-ray playback. I would like to add a secondary display for when I don't really want to power up the projector. And I would like the monitor to be capable of 1080p/24hz. The 1080p part is no problem but I am not sure what computer monitors will display a 24hz signal?
In case you are wondering, I need both displays to support 24hz because that's the way this dual-output HDMI switch works... it goes with the lowest common denominator. So if I hook up a monitor that only does 720p or 60hz then my projector is also forced down to those settings.
So, I'm looking for the cheapest, crappiest LCD-TV or computer monitor that does both 1080p and 24hz. Must be in the 20" to 32" range, no bigger. Any info would be greatly appreciated. Thanks!
