MONITOR for gtx 1080 & ryzen 1600
May 14, 2018
4
Hi guys!
what monitor do you suggest would work best in combo with a ryzen 5 1600 and gtx 1080 for 1440p gaming only (not a pro gamer 😛) with a budget of 480/500€?
Should I go with 60hz or 144hz?
as I wrote above I was looking for suggestions for a 1440p display with that budget.
For size i think 24" is good for me because im very close to the monitor
I will recommend to go for this one :- https://www.amazon.com/ASUS-VX24AH-23-8-2560x1440-Monitor/dp/B01D4TCCZ4/ref=sr_1_fkmr1_1?ie=UTF8&qid=1526285518&sr=8-1-fkmr1&keywords=24+inch+monitor+1440p
Because first it meets your requirement and second asus is a brand of its word considering the built quality and customer support is all good . plus as u said earlier ur work bench is not that big so these should fit in perfectly and i my self owna 24 inch monitor and it takes like 1/4 of my desk space considering my desk is arround 40 inch.
This is a really good choice as well with the bezel less screen it surely provide you a good multi monitor display
but do mind the refresh rate is quite high around 165hz ( basically your monitor will refresh 165 frames every second ). but noting this shoudn't be an issue for your build . so i will say yea you ca n go for this one !
