monitor for photo work
zosozep60
4
I am upgrading video card to a GTX 1080 and in need of recommendations for new monitor for photo editing. Looking for something that works best with the GTX 1080. Price range max. $700
max size 27 in.
It really depends on what gamut the photo editing is intended for. If its sRGB, then it covers 100% of the gamut. If its for Adobe RGB, then its only 78% of the gamut. You would typically want to go with Adobe RGB since its a larger gamut and will cover...
It really depends on what gamut the photo editing is intended for. If its sRGB, then it covers 100% of the gamut. If its for Adobe RGB, then its only 78% of the gamut. You would typically want to go with Adobe RGB since its a larger gamut and will cover sRGB. If I was going for a ViewSonic, I would go with the 2785-4K which covers is 99% of the AdobeRGB gamut. IT is more expensive though... $872 on Amazon.
I too am looking for a good photo editing monitor. Would prefer a 32", but would settle for a 27".
Here is a sight that give full specs on most monitors:
https://www.displayspecifications.com/en/model/d1f5d53
Here is another another site that lists a wide price range of photo editing monitors:
https://pc4u.org/best-monitor-for-photo-editing-and-photography/
Hope that helps.
