G
Guest
Guest
Hello everyone,
I am looking for a 23" - 24" monitor that I can use both with my PC and PS3. I am not looking for a high-end monitor, maximum 250 - 300$. I will use it my ps3 too so a hdmi input is important.
I usually play games on my pc and I can't decide if I should buy an ips or tn panel monitor. I know that tn has better response time but i am not much into fps games like COD or BF. I play games like Max Payne 3, Dragon Age, Batman:AC, Witcher 2, Skyrim. I also heard good things about 120 hz monitors but my gpu is gtx 560 ti, so 120 hz wont work well with my gpu right? I think I need a better gpu for 120 hz.
After some research I ended up finding these monitors:
ASUS VW246H http://www.newegg.com/Product/Product.aspx?Item=N82E16824236049
ASUS ML239H http://www.newegg.com/Product/Product.aspx?Item=N82E16824236207&Tpk=asus%20ml239h
ASUS VS239H http://www.newegg.com/Product/Product.aspx?Item=N82E16824236288
ASUS PA Series PA238Q http://www.newegg.com/Product/Product.aspx?Item=N82E16824236201&Tpk=PA238Q
BenQ RL2450HT http://www.newegg.com/Product/Product.aspx?Item=N82E16824014269&Tpk=RL2450H
Note: I won't buy from newegg.com so I am looking at the normal prices not the discounted prices
Currently I feel like IPS might be better for my use but your opinions are very important. Which monitor should I buy? Of course you can suggest something other than the monitors above.
