monitor for ps4/pc?
luisfromtx
17
will this monitor be compatible for my ps4?(https://www.asus.com/us/Monitors/VG248QE/overview/)
im sure it will work for my pc. But i'd like to buy something that works for both ps4 and pc as my current monitor does not work for my ps4
It will work for your ps4 but you do not need to spend the money on the 144hz unless you have a very powerful gaming Pc because with the frames the games on Ps4 get 60hz will be all you'll ever need. Also what monitor do you use now that isn't compatible?
i couldnt even tell you what monitor it was as im not at my house. but its def over 6-7 years old. and im not really sure what to look for as im happy with the way my screen looks now. I just want something that works for both pc and ps4. i figured to get something better then the current monitor as i prob wont be buying a new one for a very long time
