Monitor goes black for a few seconds
JohanP
My monitor keeps at random times going black for a couple of seconds, often they can occur right after each other. But it only seems to be doing this while I'm playing games. Everything is updated and it happened before I swapped to a gtx770 a year ago. Doesn't look like the monitor loses the signal, cause the the screen doesnt go blue as it does when I unplugg the HDMI. Since it jsut happens when I play games it doesn't make sense that there are something wrong with the monitor?
Also when it goes black and comes back there are horizontal lines, maybe just a pixel high, of what I can just describe as "noise". They are really small, and very hard to see, but they are there.
Simon Hudson
71
You should try uninstalling the gpu driver then download and install an new driver.
JohanP
Rolled it back, installed everything again and optimized. Has so far gone black one time while watching series. So guessing I will buy a new monitor after xmas ;)
