Question Monitor goes "Display port No signal" when launch game.
bullooka
47
When I start Game the monitor says "DP no signal" but after a moment the screen works and shows the game I started. Is it an issue?
The Display is Asus rogstrix xg248q.
Other specs
Mobo: Msi mpg z690 edge ddr4
Cpu: Intel i712700k
Ram: Corsair dominator platinum 32gig 3200mhz c16 ddr4
Gpu: Rtx3080ti OC
Psu: Corsair RM850 80plusGold
Storage: Nvme samsung 980pro 2tb/970pro 2tb
Is it with all games or with one specific game?
As of why it may happen; when you use full screen mode and in-game resolution is different than desktop resolution, it takes a bit of time for monitor to adjust to new resolution.
Reactions: bullooka
It happens almost with most of games, and yes it does that on fullscreen mode, specially if I set my display to 240hz.
Try borderless fullscreen or windowed fullscreen instead. This might fix your issue.
But other than that, sounds like monitor issue. It won't harm the monitor. It just takes some time for monitor to stop the current signal and recalibrate itself to the new signal (reso and/or refresh rate). It used to be common place ~20 years ago, so, it is strange to see it happen at current date.
Reactions: bullooka
Yes, with that it avoids doing no signal. Also that no signal doesn't bother me much, I was just worried if my monitor's dying.
