I'm having this very annoying problem, that I can't seem to fix. Whenever I set the core voltage to higher than +25 in MSI afterburner, and I run a game or benchmark, the monitor which is connected with DisplayPort starts going black randomly, for a few seconds. I have a 3-monitor setup, but the other two monitors(DVI) work completely fine.
My two crossfired graphics cards are both reference XFX R9 290's. They're watercooled, and do not reach a temperature higher than 55°C at high load. I am also sure that I can achieve a much higher overclock with increased voltage, but the monitor flashes just get worse, up to a point where it doesn't even turn on for 5 minutes at a time.
The PSU is a high end Seasonic 1000W platinum rated. Before I had a 850W one, and the black flicker was also there. Using the latest AMD drivers and updated BIOS.
I would appreciate any kind of help, to see what I am dealing with here. I really want this to go away, so I can overclock the cards further. Thanks!
