Question Monitor has grey haze, VG271UP
Fictions
Hello all,
Right now I am using an Acer Nitro VG271UP (144hz) monitor. This monitor is connected with a DisplayPort 1.2 cable. In the past, this cable worked well with my 4K 60hz monitor.
Now I have a little problem with my monitor. When I put my resolution to native (2560x1440p), there is a grey haze visible. Even on 60hz. When I go to Nvidia control panel and select YCbCR422 color space, then the gray haze will disappear. But I want to use it in RGB color space.
A solution for this is selecting a custom resolution of 2559x1440. With this resolution I can use RGB color space with 144hz.
My question is can I solve this problem with buying a Displayport 1.4 cable? I already did a clean install (drivers/windows).
Below I have included pictures. They are captured with same iso/shutterspeed etc to make it vissible.
https://drive.google.com/drive/folders/1JjoaGVMkfegXcgsbbqzxaVour__KaQIX
Can you guys help me out please?
