Hello, I've recently run into a problem with an HP 23xi monitor that I have been using for 15 months. The monitor has been working up until the other day when, during mid use, the monitor acquired a pink hue on the left side.
Photo of Gradient (monitor should be fully white:
http://i.gyazo.com/db91b19153aa027f90399bdd97053cb8.png
I'm not sure if the issue is fixable. I have tested cables, I have tested the input and outputs of the monitor and graphics card, I have also tested with other monitors that work fine. Any ideas for what I can do to fix the issue? Is the issue even fixable?
I am also two months out of warranty so getting the monitor replaced by HP is probably not an option. HP will not even allow me to submit a support ticket.
Thanks for your time. Any help is appreciated.
