[SOLVED] Monitor headphone jack works better than PC's
Sep 19, 2019
9
Having run into a buzzing noise in Rainbow 6 siege I have reinstalled the game and reinstalled all the drivers, 3 hours later, I realised that I recently started using audio extender to connect my PC to headphones, instead of having connecting my headphones to monitor like I used to before. The problem for some reason is only noticeable in Rainbow due to all the buzzing, which disappears when I plug into monitor instead of PC.
So now I'm stuck with a dilemma where the sound coming from my monitor headphone jack is better than my PC's front end audio jack. I'm thinking if it's because my monitor is fed data using Nvidia drivers, whereas my headphones use Realtek. Any way I can fix this or assign my headphones different drivers? Should I just give up and use the headphone jack from my monitor?
realtek is able to redirect headpones to any io port at back
Tried that and other jacks work just fine . But it's weird, as other headphones I tried work fine with front jack. So basically there is only an issue if I'm wearing Beats Studio + plug into that front jack + play games, which is one wacky combination..
