Monitor help please?
sciamwow
598
I want a 1080p monitor as my main monitor and to keep my 900p monitor on the side. The thing is, should I just get a $130 1080p 60hz monitor? Or should I splurge a bit ad get a BenQ for $180? But then in that case, I'm just $20 away from low-end 144hz monitors... Please help!
Unless you have a system that cant utelise those 144hz, id just get a normal 60hz monitor. If your can run above 60 fps then id het the 144hz, even if you dont get a constant 100+ fps its still worth it
EDIT: Saw your specs get a 120/144hz monitor.
