Monitor in Power Save Mode After New GPU
Sep 26, 2018
5
I've had a huge headache since buying a new graphics card. I've combed through these forums and other forums for help and have reached a dead end. Here's my basic set up:
Intel 4770k CPU
GTX1080 Ti
Seasonic 80+ Gold 650W PSU
16GB DDR3 RAM
Dell E228WFP 22" flat panel widescreen monitor (pretty old)
Asus Z97A Motherboard
I bought the 1080Ti to replace my aging GTX780. The 1080Ti was an open box item I bought at a pretty good price--the sales person said it was tested and worked fine. I got home, installed, fired up the computer, and immediately downloaded the latest drivers. I also did some Windows updates that were pending. Restarted the computer, and here's where the headache started. Goes through POST, then I hear the Windows "start up chime." However, my screen is black, and my monitor just has "power saving mode" scrolling across it. the 8+6 pins are snug, the card is locked into the PCIe slot. The fans are spinning and it's lit up. Hmmm. So I immediately think that something is awry with the drivers or windows update. Do some searching, boot in safe mode, and do a system restore in hopes it will work again. No dice. Do some more research, boot again in safe mode, download the DDU program, and wipe all of my NVIDIA drivers, thinking my old card and new card's drivers are conflicting. I do all this in safe mode, restart, turn off, reinstall the card, and same problem. Now I'm sure this open-box GPU is garbage, and someone lied to me. So I take it to a computer shop and ask them to put it in one of their builds and see if it works for them.
In the meantime, I am putting my old GPU back into my computer, and now I'm having the same issues--I can't even get the 780 back functioning. I run the DDU app to get rid of possible old 1080Ti drivers, but when I boot, I'm getting the same problem. Windows chime is audible but the screen is black. Everything appears to be working in the background--I can enter my password and hit enter, and the log-on sound goes off, so that's good I guess. But I can't see anything. So, now I'm wondering if something is wrong with my motherboard/PCIe slot. I switch out to another slot, but same problem.
Go back to the computer store, they say the 1080Ti works for them. So that rules out the card. Unscrew my DVI cable, resecure it (yes, it's plugged into the GPU)...I remove the GPU, plug the DVI cable into the onboard Graphics so I can see. Try the 1080 GPU again, reinstall drivers--this time old drivers--no dice. I update BIOS. No dice. Take CMOS battery out. Take jumper out. Try hooking my TV up to the GPU with an HDMI cable. Nope. Remove RAM and reinsert RAM. Clean components. Nothing. I've gone into BIOS and try to force it to read through PCIe, it doesn't work. My PSU should be adequate for my build.
I'm pretty much at a loss here. I was concerned it had to be my motherboard, but I really don't want to go buy a new one and essentially reassemble everything unless I know it's at fault. When I go into device manager after physically installing the 1080Ti, under display, it says basically I'm using onboard graphics, which makes sense, since no drivers are installed. After I install drivers, reboot--black screen. To make sure it was actually recognizing the device, I booted in safe mode, went into device manager, and it now lists the 1080Ti under devices. This means that it is actually being recognized by the Mobo, right? And it's not just listed there because there are drivers for it?
One last thing that may or may not be relevant. Occasionally, I will get to the windows splash screen--but it's frozen there. It still makes the chime noise...but the display is frozen (however, I don't have the black power save mode message).
Anywho, thanks for any help. It's incredibly frustrating and maybe I'm missing some steps or haven't thought of a few things.
How did you update the BIOS? Which version is installed now?
Reflash the BIOS again with the latest version using:
ASUS EZ Flash 2:
Updates the BIOS using a USB flash drive within BIOS (don´t flash in windows)
Also you can try flashing by ASUS CrashFree BIOS 3 utility
before using this utility, rename the BIOS file in the removable device into Z97A.CAP
Did you clear the cmos by jumper correctly after installing a different card? jumper to pin 2 and 3 for a view seconds and back to pin 1 and 2, while PC is disonnected from the wall
Try Ubuntu live, if it boots correctly.
try a different PCIe slot
Use contact spray to clean the contacts of your PCIe slot
check again if the PCIe graphics card is deeply inserted
edit:
be sure EPU...
For what you said it looks like we have 2 chances:
1- They lied you and the card its not actually working as intended...
2- If you have a friend or someone you know that can borrow you the PC to install the 1080 Ti there for a couple of mins maybe you can actually check what's goin on.
I would do the following Test:
Get anyone else PC with a PSU capable of handdling a 1080TI.
Then, Connect the 1080TI, install its drivers and see if its working.
IF it does work. Connect YOUR seasonic PSU to that testing PC and check if the 1080ti still works.
If it does work, its your mobo. If it dosent its the PSU. If it does not work on ANY of the 2 tests, its the GPU.
Hope it enlighted you,
Cheers!
Update... ended up taking in my rig to a computer store so they could test. They couldn’t get the GTX1080 Ti to work. They tested my PSU... They finally said that my motherboard just wasn’t compatible with the 1080... rather, the Asus Z97-A Wasn’t listed AS compatible. I just find it hard to believe they won’t work together. I’m trying to do research of my own. In the mean time, does anyone know?
no, they just lied you. There is no such thing as a Mobo with a PCI-E slot is not compatible with a 1080ti.
I wouldnt ever ever Purchase on that store ever again.
And also i would just take the money back.
Here is a list of all PCS with YOUR same motherboard & the Gpus with 1080s, 1080s ti,1070,etc.
http://www.userbenchmark.com/System/Asus-Z97-A/4712
So reclaim your money back cause they are just trying to scam you.
ASUS EZ Flash 2:
edit:
be sure EPU and TPU switches are set to disabled
Thanks for the response. I have tried all the PCIe slots. I updated BIOS on a USB stick using EZFlash to the latest version. I did try using the jumper as well, as you described. I am not familiar with EPU and TPU, I'll have to research that.
The computer shop told me that the 1080Ti works in other systems they have--but not mine. They maintain that since my Z97A card is not listed as officially compatible, that must be the issue. They also said that they can now only get my GTX780 to run if they install a fresh copy of windows. Although I don't buy the mobo compatibility issue, I still feel like it might be a hardware issue.
