Hey guys, let me get a couple of opinions. First off, system specs.
Athlon x2 5200+
2gb ddr 667 ram
Galaxy 9600gt(factory overclocked version).
PSU is an Ultra LSP 650 watt with 38 amps on the 12v+ rail, should be more than enough for this rig.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3276573&CatId=1483
I run the stock cpu cooler, and for cooling, I have a 250 mm side intake fan, exhaust fan, as well as pci slot cooling fan underneath the 9600gt. Typcially the card itself idles a little under 40 degrees celcius. CPU typcially stays in the 30's at idle. Pretty certain I've got more than enough juice considering that PSU. But was playing a game recently, and after a couple hours of playing, the monitor lost signal, note the pc did not lock up, it came back after adjusting the cable. Still had sound, etc. Just weird though, as I've not seen this issue before on this machine, and honestly this pc is not used that much, the occasional game here and there.
The monitor is a 22 inch hanns g, with vga and hdmi inputs. I only have a vga cable, so it's being connected via a dvi-vga adapter coming off one of the dvi ports on the 9600, and into the vga input. Aside from of course the cable being possibly loose, is there anything else that could cause this issue? Fault of the adapter maybe? Would it be better to maybe get hold of a dvi-->hdmi cable to run straight into the monitor and skip the adapter altogether? Thanks for the input. Again, not a huge deal, but would be nice to know so I can correct it.
Athlon x2 5200+
2gb ddr 667 ram
