Hello
I was searching the forum and I didnt find that anyone had any problems like mine 🙁
So I would like to ask if someone haves any suggestions or answers for the problem
The problem is that my monitor BenQ FP71G+ LCD Monitor is losing the green color. The thing is that its sometimes blinking,but blinking in a way that when is blinks it loses the green color,and the whole monitor turns pink or violet(R+B only,instead of R+G+B).
So my solutions were to re-solder the board inside,and even change the Capacitors and a few MOSFETs,but with no luck...
Now even when I turn on the monitor it needs at least 5 minutes to "heat up" and gain the green color,but after 1-2 hours of working on it,starts losing the green color again(blinking).
But the weird thing is that when it loses the green color,when I go into the Menu in the monitor,there the green color didnt go away,only "behind" the menu(the display signal that it gets from the computer).
Now I tried even to put in a graphics card,because its running on a integrated graphic card on a ASUS P5N73 MoBo(thought even maybe the MoBo is doing the problem),but with no luck.Tried it on a other monitor and everything works fine.
So I,once again, turned to Tom`s Hardware for I have found the website to be the best for any kind of questions and suggestion regarding to computer SW/HW
I thank you in forward for any answers and suggestiongs
Best Regards
Best Regards
